Hi,
No features is disabled when you have the camera outdoor, as longs it`s powered with cable?
And of course the temperature is not below the ratings...
Example look back, activity zone and CVR is working as it was indoor ?
The look back (now called "Foresight", Activity Zones, and CVR will all work with the camera outdoors as long as the camera is AC powered.
Activity Zones will also work if you are on battery power and have a paid subscription. In that case the activity zones are processed by the Arlo Cloud (instead of in the camera itself).
