Outdoor USB power outlet to run continuous power to Pro 2
  • 1 Reply
  • 647 Views
MNair
Looking to replace existing outdoor power outlet with an outdoor power outlet with USB ports to run continuous power to Pro 2.  Main issue I have is that existing Arlo outlet does not fit in my tamper proof box/outdoor cover.  Does anyone have any experience with and/or can suggest an good brand / model of outlet?
Thanks.
JessicaP
Hi MNair,
When you say you're having problems with the existing Arlo outlet, are you referring to this one: Arlo Outdoor Power Adapter for Arlo Pro, Pro 2, Go and Arlo Security Light - Black?
  • 1 Reply
  • 648 Views
