Looking to replace existing outdoor power outlet with an outdoor power outlet with USB ports to run continuous power to Pro 2. Main issue I have is that existing Arlo outlet does not fit in my tamper proof box/outdoor cover. Does anyone have any experience with and/or can suggest an good brand / model of outlet?
Thanks.
Hi MNair,
When you say you're having problems with the existing Arlo outlet, are you referring to this one: Arlo Outdoor Power Adapter for Arlo Pro, Pro 2, Go and Arlo Security Light - Black?
