one of my pro 2 cameras went dead, wouldn't charge or connect to base. I removed device and now it will not sync. I have to charge the battery in a different camera to get it to blink blue to try to connect. but never will sync. the battery dies and I have to do that all over again and still with no success. Help me please.
Will it sync if AC power is applied (might be worth trying this with the battery in as well as out to see if there's a difference)?
If the battery is totally dead, you may need to follow the procedure outline in an FAQ here to revive it. It's basically plugging and unplugging the camera at least 6 times to get enough charge in the battery for it to respond properly.
i will try that right now!
