Hi, I have 6 Arlo Pro 2 cameras. Somehow, one of them has not recorded anything from 11:30 am thru 7pm. Do you know why? Thanks.
Loi
It may be as simple as no movement that the camera could detect. However, make sure the mode you're using has a rule for that camera and that it's configured properly. Reboot the base. You may need to remove the camera and resync.
the camera operate in this kind of behavior in a few days and now it runs normal as other camera. Thanks for the advice.
