Cameras not syncing Arlo Pro 2
  • 24 Replies
  • 15186 Views
  • 2 Likes
  • 7 In Conversation
SammyK
I have just unboxed my arlo pro 2 kit and have installed the base station all according to what it says. When I try to sync the cameras (one at a time) they won’t sync. The sync light flashes on the base station and the blue light flashes on the camera for about a minute, then a fast amber light flashes on the camera and it stops trying to sync.
I have tried with both cameras and have the same problem. I have reset the base station and started again, twice. I have tried to plug the camera into power, and always get the same result.
Has anyone got any other ideas?
24 REPLIES 24
ShayneS
Hi @SammyK
Are you still having an issue syncing your cameras?
SammyK
Yes. Still doing the same thing and not syncing. Have you got any ideas/suggestions
ShayneS
Is this a new system or used?
SammyK
Brand new. Straight out of the box
ShayneS
I see it is offline at the moment, do you have it unplugged or are you experiencing an offline issue as well? Can you provide me with the firmware version?
SammyK
I have just had it unplugged. It’s online now. Firmware is 1.12.2.4_2772
ShayneS
The newest FW version for your base is 1.14.0.2_2776 The base should try and update around 3 AM Pacific Time.Automatically. Do you see Settings > My Devices > Select Base > Device Info > may display needs a firmware update. - Firmware Release Notes
SammyK
It’s saying that there are no updates available.
ShayneS
You can try and do a few reboots and wait a few minutes between each attempt, or let is sit overnight and wait for the FW to come through. Sometimes it takes a bit for it to push. if you like, you can also contact Customer Support regarding this. I will provide the link here for you. Arlo Tech support
SammyK
The firmware is now up to date and the cameras still won’t sync
ShayneS
The cameras are within 6 inches or closer to the base station right?
dipaknpn
Hi,
I got two Brand new Arlo Pro 2 (3 Camera- and Base station in each box). First I opened a box and connect the Base station. Then I try to connect single camera each time tried more than 13 hours .. whole day but never get successful.  It was a brand new and I am not able to connect at all.
I thought that box had issue.
And I tried a another box. Happen same issue. I reach out arlo customer service for technical support still they are not able to resolve it.
Can someone help me out or having same issue??
Regards,
Deepak
ShayneS
Hi @dipaknpn
What are the status LEDs displaying on the front of the base station?
dipaknpn
While putting battery - It blinks Blue once.
While pressing synch - it blinks blue slowly and later turn to amber and nothing it will display.
ShayneS
When looking at your base station, what do the status LED lights display? I have provided a picture below.
dipaknpn
1. the Base station light display Green for Power and Internet.
2. When you press Synch button - it will blink green for sometime then amber and it will not display.
ShayneS
@dipaknpn
Are you pressing the the sync button on the base station, then the cameras? You are keeping the camera within 1 foot of the base when syncing correct? All of the cameras will not sync?
dipaknpn
Yes first base station - synch button then only camera  (single camera) .
Camera - is within 1 feet only.
ShayneS
@dipaknpn
I would suggest following the advice the support agent gave you within your case, or contact them again to let them know the issue is persistent.
dipaknpn
Hi,
I reached ARLO support team. They told its base station issue - Case Number 41304790.
And I get the new alro set again. But having same issue. I do not think it's base station. It's something other issue. No idea why my cameras are not synching up. I feel now i got the wrong device.
I_In_The_Sky
I have the exact same problem...
Sad the company does not seem to care..
Mattroy10
Same issue here. My camera was working fine, but I let the it sit with a dead battery for a few months and it would not reconnect after charging. Removed it from app to try to re-sync it, but still no luck.
joe1821
What I would try is this: Remove the battery from the camera for about 1 or 2 minutes then reinsert it.  What I have had to do to my system is to reset the hub and then remove the batteries on both cameras.  You're rebooting the entire system and that will clear any registers that have corrupt data in them.  If you get results or not please post here so that Netgear can see the progress of problems with the Arlo Pro 2 system.
Try this: https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
  • 24 Replies
  • 15187 Views
  • 2 Likes
  • 7 In Conversation
