  • 14 Replies
  • 1696 Views
  • 8 In Conversation
Panthersnr
My cameras have stopped recording to the free 7 day cloud service
14 REPLIES 14
Several users have reported this recently with their systems.   The mods can fix it remotely, so I am tagging them to call attention to your post - @BrookeN , @ShayneS , @JamesC .  They might not respond over the weekend, so give them some time.
ShayneS
Thank you for bringing this to our attention. Are you still experiencing this behavior? I have notified the team and I will provide more info as soon as I can.
samiam1966
My cameras have stopped the 7-day recording, too.  Does anyone know why?
ShayneS
Hi @samiam1966
Can you reboot your base station and test this again, I had the team make an update on the backend.
ShayneS
@samiam1966
How did this go?
TobG
Hi. My Arlo H4 moving detection have stopped working. Any tips on what can have gone wrong and how it can be solved? Have consulted Arlo's support quide/FAQ, and Google'd about it, but not found any solution.
If the issue is that you get no recordings, be sure you have a subscription which is required. The free trial sub may have expired.
@TobG wrote:
My Arlo H4
H4 is a hardware revision code, not the camera model.  The cameras have overlapping H codes, so we cannot determine your camera model from this info.  The model should start with either VMC or VML.
Can you get the correct info?  One way is to open the camera, remove the battery, and look at the label behind it.  Another way is to go into the support center in the app, select the camera, and scroll down to the product id field.
Also, do you have other cameras?  If you do, are they working?
heron3
I am also having this issue with all 4 of my arlo pro 2 cameras. I restated the base station a few times and unplugged and removed the battery in one of the cameras  to test it out but still the same. The live cameras work but no recording or motion detection. It seems like when I click Mode and set it to Arm all devices and click to check the Armed setting is not checked. When I try to manually click on Armed after a second it uncheck itself. I can select Schedule which seems to show it's armed all the time per schedule but this doesn't seem to matter.
The mods ( @BrookeN , @JamesC , @ShayneS ) can do a back-end sync that likely will fix this, so I am tagging them.
Another thing you can try is removing one camera from your account, and then adding it back.
ShayneS
Hi @heron3
Can you reboot your base station and test again?
heron3
I'll try these.
BrookeN
@TobG can you check the cameras now and see if you are seeing the same behavior?
heron3
I did both I restarted the base station and removed one camera and then reinstalled it. Eventually all 4 cameras are now working again! Thanks I don't know if someone did something on their end or if what I did fixed it but seems to be detecting motion again and recording. Hopefully this won't happen again so I won't have to climb up my ladder to grab one of the cameras again.
  • 14 Replies
  • 1697 Views
  • 8 In Conversation
