Old battery and brand new battery both not charging
I had an extra Pro 2 camera in the closet I wanted to add to my system. It had a battery, and I also have a brand new battery I opened up. Neither of them will charge when the camera is plugged in. I see the green lightning bolt on the app, and the plug icon like it's plugged in and charging on the web interface, but I unplug the camera after hours and it says the battery needs charged.
I see solutions (like the 10 minute unplug for 5 times method), but that is not my exact situation because I AM getting the lightning bolt icon when its plugged in.
Any help would be greatly appreciated.
Do the batteries charge when you put them in another camera?
make sure you are using the original charger cable and ac adapter setup
I don't have the original. Just a new battery that I purchased that came with a charger (OEM)
I also tried other cameras on the system, same issue.
What have you been using to charge the batteries before you purchased the new battery+charger???
The other cameras on the system have always just been wired with no battery. So basically this is my first time attempting to run one with a battery.
Post a pic if possible on the battery label...
If you look at the battery it should be listed as 7.2v ( charges to 8.4 max )... and should work with a 5v USB with at least 1a or more.
Also make sure you have a Pro2 camera, as the Pro camera that uses the same battery NEEDS a qualcomm type charger that output a dual voltage of 5v/9v.... 5v to run and 9v to charge the battery.
