Try the following steps to see if you're able to change the notification tones through your phone settings: Use your Google Phone 2XL settings > Apps > Arlo > Notifications > Notifications (click on it again) > Advanced > Sound.
Hi @Fireball2684,
If you are using an Android device, you can change your notification preference directly from the application settings.
For extending the record time, add this idea to our Idea Exchange Board. Our development team routinely reviews posts in the board to assess which features the community would like to see implemented.
Hi Jessica, I am using Android but that feature is not available as you say. I am using the Google Pixel 2xl. Everything is fully up to date. There's no way to change the sound. It only uses the default settings.
After checking out the settings last night, I figured it out. I didn't realize that I can click on notifications. I thought it was only a toggle switch. Thanks for the help. Much better now...lol
