Noticing a lot of pixelation at night on all cameras. Tried rebooting/resetting.
Hi - Just purchased and setup the Arlo Pro 2 base and four cameras today and I am noticing a lot of pixelation at night across all cameras. The pixelation follows a cycle where it appears to get worse over a couple seconds and then resets (gets better). I have rebooted/reset the base and reset up cameras with no luck. Also, a couple of the cameras are close to the base, so distance should not be an issue.
Curious if anyone else has run into this?? Thoughts?? Thx!
Edit: Should have mentioned that all firmware was updated automatically too.
Can you try and move the base a bit farther away from the router ? ( longer ethernet cable )
I too just bought the 4 camera system and I’m having the same problem. All 4 cameras have pretty good pixelation going on. I moved the base away from the router, but that didn’t do anything. Really frustrated because I want to love this system but there’s no way the video is 1080p! I’m seeing the pixelation all the time.
Great suggestion!
How much farther away did you go from the router?
