I have 2 Base Stations. Should I have them apart or is it okay to have them next to each other?
Quick question, I have 2 bases should I have them apart or is it ok to have them next to each other? 1 Base is for the back of the house and the other is for the front. Will they interfere with each other?
I have them apart myself (one in the front and one in the back of the house). Though I have had two bases fairly close together (perhaps 6 feet) with no problem. So if it's inconvenient to put them in different places, perhaps just try it with the bases co-located.
Same here, while I run a third base off a satellite ( orbi setup ) right near the main router I have one on each side without issues...
Do what works best for you ( but I would keep a min distance of a 5 ft).
