  • 2 Replies
  • 752 Views
silverado44
Virtuoso
Virtuoso
Quick question, I have 2 bases should I have them apart or is it ok to have them next to each other? 1 Base is for the back of the house and the other is for the front. Will they interfere with each other?
I have them apart myself (one in the front and one in the back of the house).  Though I have had two bases fairly close together (perhaps 6 feet) with no problem.  So if it's inconvenient to put them in different places, perhaps just try it with the bases co-located.
Same here, while I run a third base off a satellite ( orbi setup ) right near the main router I have one on each side without issues...
Do what works best for you ( but I would keep a min distance of a 5 ft).
  • 2 Replies
  • 753 Views
