Even though i´m recording on my USB stick, I can not see that my recordings take some space.Does not it record ? and what can you do ? I have formatted it and it also writes ready
There is no way to view what is recorded on the USB stick unless you eject it and plug it into another device to view the mp4 files.
Make sure you format the usb stick in the base by settings... A small USB stick icon appears over the Live View camera when a usb stick is used.
There were some issues when using mem cards in a adapter device, But have not heard many with quality speed usb sticks
