There is no recordings shown up in the app but when I clicked on email link, the video is there. Is something wrong happened to the server that connects to the app?
check on the web access to see if it's the actual system or the app itself https://arlo.netgear.com
I've been having issues with Pro 2's not recording but showing motion man lit up.
i will try your emal method and see if i can then view video.
i've reset base station 2x and took out the battery with no change.
I got email alert as well. If I clicked on the link in the email, I can watch the video. Just that when I opened the app, nothing shows up. It happened many times before but usually after I restarted the app, videos will appear. But last night it did not show for an hour including the past 7 days ones. That’s why I raised this question here. Thanks
