I’ve been using the Arlo Go so I’m familiar with the options for arming the camera to trigger by sound and/or motion.
I just purchased the Arlo Pro 2 set, but there is no option to trigger by sound. Under mode, there’s only the option under the rules to trigger by motion. What is missing?
Message 1 of 3
1,126
If you edit that rule, you should see a checkbox for both motion and audio detection. Are you not seeing that?
Message 2 of 3
1,113
Message 2 of 3
1,114
Thank you!! I would never expect to edit a motion rule in order to add an audio, that’s misleading how they display that!
Message 3 of 3
1,105
