No option for audio detection Arlo Pro 2. Under mode, only option under the rules to trigger motion?
  • 2 Replies
  • 1076 Views
zubiedoo
I’ve been using the Arlo Go so I’m familiar with the options for arming the camera to trigger by sound and/or motion.
I just purchased the Arlo Pro 2 set, but there is no option to trigger by sound. Under mode, there’s only the option under the rules to trigger by motion. What is missing?
If you edit that rule, you should see a checkbox for both motion and audio detection.  Are you not seeing that?
zubiedoo
Thank you!! I would never expect to edit a motion rule in order to add an audio, that’s misleading how they display that!
  • 2 Replies
  • 1077 Views
