  • 7 Replies
  • 2179 Views
Tree7
My 7 cameras were working yeaterday but today they will not show a live stream or notify me of movement. I have unlinked and linked the cameras, powered on and off, rebooted router, rest base station, everything i can think of I've tried. The cameras show on my phone as they are working, all lights on base station are green. I checked to make sure cameras were picking up motion, which they were but nothing. This is ridiculous. Very VERY poor from Arlo. There is always problems. Can't wait to get rid of them.
7 REPLIES 7
What cameras and base station(s) are you using?
Tree7
Arlo Pro 2 and the older base station. See pic.
That looks like a VMB4000 base.  There should be a label on it that you could use to confirm.
All seven cameras appear to be on line, but give you a connection timeout error when you live stream?
Do they also do this when you use a PC (https://my.arlo.com)?
Tree7
Hi,
The base is a VMB4000.
When trying to veiw the cameras on my laptop they say "it looks like the device is busy or offline".
It's really annoying. I have 2 properties and the same set up. The other cameras at my second property are working fine and i can connect to my phone no problem.
There is a connection timeout when trying to show them on my galaxy s9.
Thanks for your help.
Show quoted text
@Tree7 wrote:
When trying to view the cameras on my laptop they say "it looks like the device is busy or offline".
If you haven't restarted the base, I'd try that first.
Tree7
I have tried just about everything
It's hard to know how to helps if we don't know more about what you've tried.
You could try removing the base from the account, and adding it (and the cameras) again.
  • 7 Replies
  • 2180 Views
