  • 4 Replies
  • 4133 Views
Erilekn
VMB4000 BASESTATION has tre light. But today i have no green light in the middle. Its off. Camera works. All my other devices are on internet. I think its not connect to server? How can i solve this?
NewfieDrool
Luminary
Luminary
I take it you have turned off your basestation the turned it back on?
if that fails reboot modem or try another port in the router.
NewfieDrool
Luminary
Luminary
Also check that the ethernet cable is fully inserted into the socket in the base and in the router.
Erilekn
I did the first thing. On and off the basestation, and its ok. I think after the firmware update, when its blinking and talk to server all the time, it has a little bug and stop blinking and stayd off.
NewfieDrool
Luminary
Luminary
Glad it’s sorted, sometimes if it loses connection an on off works. Some routers shows logs and sometimes you can find out the cause if you need to dig deeper if it’s related to the network side of things.
  • 4 Replies
  • 4134 Views
