VMB4000 BASESTATION has tre light. But today i have no green light in the middle. Its off. Camera works. All my other devices are on internet. I think its not connect to server? How can i solve this?
I take it you have turned off your basestation the turned it back on?
if that fails reboot modem or try another port in the router.
Also check that the ethernet cable is fully inserted into the socket in the base and in the router.
Glad it’s sorted, sometimes if it loses connection an on off works. Some routers shows logs and sometimes you can find out the cause if you need to dig deeper if it’s related to the network side of things.
