The two step verification code is not working. I have requested the code tow be sent by email, the email comes through from Arlo, however there is no code attached to the email. I can’t use the other verification method as I have recently changed phones and Arlo doesn’t recognise the device. Think there is a problem with the email sending verification code and there isn’t a code attached.
You can add your new phone as a trusted device just like you did with your old one to get a code or push notification. For e-mail the code should in the narrative of the e-mail, not attached.
Hi Chell,
I would suggest for you to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Let me reach out to you via private message to gather more information from you.
Thanks for letting me know about this. I've escalated your case again to the team and they should be reaching out to you after they look over your case.
If you still don't hear back after two business days, please let me know.
