No Siren Volume Control
  • 2 Replies
  • 6382 Views
  • 3 Likes
JayWazy20
I cannot find where to change the volume of the siren or even add siren as a response. I have read all the different troubleshooting instructions. When I got to Mode —> base —> Armed —> edit to make a new rule there is no siren options. Also tried creating a new mode bUt there are only options for recording in response to motion/audio.
steve_t
Master Master
Edit the rule. There should be a first box that says motion is detected for that camera. The second box is likely to also be that camera and it says to record video. Below that is a box that says Add Device. Click this. Down the bottom is a device list of Alarms showing the base station with a red siren icon. Select this device and click Next. This will prompt you to select how long you want to siren to run for as well as how loud the siren should be
slompochomp
Luminary
Luminary
Here are some images to help and a link. BTW I used chrome browser, but it should be the same in the App.
How do I create a rule that includes a siren trigger?
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
steve_t
Master Master
  • 2 Replies
  • 6382 Views
  • 3 Likes
