I just received one arlo pro 2 camera, to add to my arlo pro system. The night vision is very poor compaired to arlo pro. If there is no fix ,i will return the arlo pro 2 camera. Sorry to say
How is it poor? What hardware version and firmware?
Can you see if there's a firmware update available? You might need to restart the base
1.9.4.0_15548 Base station firmware .i did a restart. Pro2 poor night vision. , pro1 good night vision
My base is on the same firmware but my Pro 2 cameras have a newer firmware
You have the latest firmware now.
My P2 night vision isn't as bad as some have posted but is lacking somewhat in contrast and/or definition compared to my Pros.
Johnny290 wrote:
Maybe I had a firmware update overnight I'm not sure how is your night vision working on the pro 2 cameras
Mine work great. Marginally better than the Pro cameras, which was a nice surprise since a few people reported they were worse. Also on H3 hardware with the latest firmware. Perhaps it is a faulty camera. Playing with the brightness setting doesn't help enough?
OK cool. Fingers crossed that fixes it!
I have 6 of the Pro 2 cameras and a bunch of the Pro and Standard Arlo wireless cameras. Two of my Pro 2 cameras appear to have night vision issues, but both of those cameras have the silicone skins on them. I trimmed the hood on the skins because I knew that IR scatter would ruin my night vision. However, those two cameras still have issues and I suspect it is IR scatter. When I am at that location the next time, I will trim the hood completely off and see if it helps.
I just took another Pro 2 camera (with no skin in it) outside to check it and it has excellent night vision which matches my experience with my indoor Pro 2 cameras.
Do any of you have silicone skins on your Pro 2s? That seems to be my only night vision problem.
OK, I did more tests and I see differences now. The Pro 2 images are a bit darker, but also wider angle. Notice the side of the garage on the right and a trim board on the upper left. The two cameras are side by side about two inches apart. I tried both Best and Optimized image quality on the Pro 2 to see if higher resolution exacerbated the problem. I did not see a difference. I do recall reading somewhere that higher resolution cameras require more IR light and naturally produce darker night images. I remember reading about this on the Axis site. I think it is why they don't offer 4K cameras with IR capability.
Pro 2
Pro
That stinks. And no light scatter from any nearby objects? Also the dumb question about the plastic having been removed from the front of the camera?
Assuming Night Vision is turned on in settings (another dumb question), it sounds like you have a defective camera. Perhaps the IR illuminators are not working at all. If you have some other IR camera, you could point them both in the same direction and turn them both on. If the Arlo could "see" using the IR illuminators from the other camera, that would seem to indicate the IR LEDs are not lighting up. Curiosity only, of course, since a defect is a defect no matter what.
Bummer. Definitely sounds like a factory defect.
I've heard that also. I did a quick test in my garage between a Pro and a Pro 2, but I didn't do a really good test. In the quick test, I couldn't detect a difference on my cameras. I'll have to do a better test with another person at the other end.
