My system cutting off
How in the world do you reach a live person to resolve an issue with my system cutting off after it was working yesterday?
Should I just throw the system in the garbage and buy a different companies cameras?
I have the same problem / I have 3 separate systems (11 cams) & some work on & off / good till 11:30 pm then off till 7: am / I keep changing cams that seem to have different sensitivity to movement etc / I am very discouraged with the set-up & almost seems the company is "throttling-back" the tech ability of the older systems hoping you will upgrade / NOT a confidence builder !!!
Hi,
Can you provide more detail regarding the symptoms you are experiencing?
Thank you
