My system cutting off
  • 2 Replies
  • 1300 Views
OllieZiffel-
How in the world do you reach a live person to resolve an issue with my system cutting off after it was working yesterday?
Should I just throw the system in the garbage and buy a different companies cameras?
greyowl10
I have the same problem / I have 3 separate systems (11 cams) & some work on & off /  good till 11:30 pm then off till  7: am   /   I keep changing cams that seem to have different sensitivity to movement etc /  I am very discouraged with the set-up & almost seems the company is "throttling-back" the tech ability of the older systems hoping you will upgrade / NOT a confidence builder !!!
ShayneS
Hi,
Can you provide more detail regarding the symptoms you are experiencing?
Thank you
  • 2 Replies
  • 1301 Views
