My Push Notifications Do Not Works With Iphone XS MAX
unfortunatly after chnaging Iphone to XS MAS, push do not works, I tried to use Iphone X and no problem.
hope some one can help.
parameters between XSMas and X are indenticall.
We are having the same problem. I am very disappointed. The push notifications does not work with the Iphone Xs. I hope Arlo can resolve this asap!
What version of IOS are you running? Can you download IOS 12.1.2 & test again?
Brendaliz.
I also confirm the push notifications do not appear to be working with iOS 12.1.2 and V2.7.0 on my iPhone XS.
@ShayneS wrote:
Have you tried to remove & re install the Arlo Mobile App and test again?
I can only speak for myself, of course. I have tried force-closing, removing and power cycling my iOS device and then reinstalling the Arlo app.
I’ve tried everything but nothing works.
My problem appears to have been resolved. I am receiving notifications on my iPhone XS (not a Max) and on my Apple Watch.
Hi Brendalizdg,
Do you have the latest IOS version installed on your IPhone xs? Also, have you downloaded the latest app version 2.7.1? Firmware
@ShayneS wrote:
Hi Brendalizdg,
Just to be clear, Brendalizdg is having problems with the iPhone XS Max....not the regular XS.
It would be helpful if links to “software” updates didn’t refer to them as “firmware”. People have enough trouble keeping them straight as it is.
Hi @AncientGeek,
This customer states they have an Iphone XS in this thread.
Brendalizdg
"We are having the same problem. I am very disappointed. The push notifications does not work with the Iphone Xs. I hope Arlo can resolve this asap!"
My mistake. I didn’t go far enough back in the thread and let the thread subject confuse me.
