My Arlo Pro 2's base station's middle Internet light is currently off and yet it still works remote
Also, its internal IP address is pingable. I will just leave it alone (not rebooting) until it gets worse. Crazy Arlos. 😛
Yes, have seen this before... all working with led off
Only fix for me was to reboot the base.
Hey, the light works again. I didn't even do anything! Yep, crazy Arlos.
Since you had this problem, I assume others too. Arlo needs to fix it!
