Arlo 2 cameras stopped recording to library but still get notification
My Arlo Pro 2 system is 3 months old. Last night it said AC power was disconnected. I removed activity zones and it is still not recording anything to library but I do get notifications that motion has been detected. Any help would be greatly appreciated.
STart by rebooting the base. Do you have local storage enabled? If not, use a 16GB or greater thumb drive and configure it in the base settings. Then see if you get local recordings when you get the notifications. Do you have Arlo Smart? You won't see cloud recordings if the motion is determined to not be one of the selected types.
