My Arlo Pro 2 Camera Will Not Re-sync It blinks Amber/Blue
  • 1 Reply
  • 888 Views
rickturco
One of my cameras will not sync.  I thought it was a bad battery and I have replaced it but have the same problem.  I have reset the base station, deleted the camera, can't re-add and if it lights up, it is just amber/blue.  Sometimes I can see the IR lights as well.
Tried all previous solutions that I could find.
Try briefly pressing the base sync button - don't hold it - and then the camera button. If that doesn't help it sounds like the camera has a major fault. You've done what I would have suggested.
  • 1 Reply
  • 889 Views
