I was very excited to receive my Arlo Pro 2 package approx 3wks ago. Since then the excitement has been replaced with disappointment and frustration.
Problem:
Every day between approx 10am-4pm (eastern), during days where the Sun is out- I receive multiple false notifiactions, ranging from minute to minute to a few mins apart. The camera is positioned on our back screened in porch, facing the "south". There are no trees or other locations which would work to re-locate it, if I were to move it the range would be to far from the base station and it would also prevent the camera to pick up the views which would be beneficial. Aka it would be useless.
Attempts to trouble shoot:
1. Powered-down, restarted, re-synced cameras etc, re-installed app, still got false notifactions.
2. Swapped camera with the one in the front(faces the North) and I still receive the false notifications.
3. Called Arlo help #, created a ticket, ran through the trouble-shooting guide, was a complete waste of an hr+ of time.
4. Exchanged the Arlo Pro 2 camera with a new package, set it up today and still receive the false notifications.
Your help would be GREATLY appreciated, I have searched this site and have found similar posts, but nothing that provides a resolutuion to my issue. I think my situation maybe slightly unique in that our house faces the north and therefore the camera in our backyard (facing the south) will always have a abundance of sunlight on days the sun is out-which is also most days. This is my last attempt to keep these cameras but time is running out for my return of these and full refund.
I know this is an "Arlo" site, so if its allowed I'd love to of course here remedies to this issue, but also open to recommendations for other brands.
Thank you very much,
A bad camera can produce false detections, hence notifications, but you didn't verify that you're changing settings in your modes and rules rather than the motion detetction test. It has to be in the rules and be saved.
Many folks use two custom modes so motion sensitivity settings can be customized for day and night. The sun's IR is very strong and reflects from many surfaces such as cars, branches and leaves. I suspect that the sun's angle, which changes as a function of time/seasons, is causing the false triggers. Reduce the sensitivity setting for the camera in your modes and rules (there are FAQs here on exactly how to do that). DO it in relatively small increments until you minimize the false detections while still getting the ones you need.
Also, post screenshots of the cameras for positioning suggestions - maybe they're just positioned poorly.
The 1st set of cameras I had I did reduce the sensitivity down to 1% and still received notifications as well. I'll try it with these as well, thanks again!
So, I haven't received "pop-up" notifications on my phone since the new set up(new base/cameras) has been used, which was yesterday afternoon. I've set them both on my phone and the arlo app, but nothing. The emails come through but would be nice to have the pop ups as well.
I'm having the same issue. I get alerts on 3 cameras every 2 minutes. It might be the sun. But I can't find Mode/Rules. I just have Mode, when I click on it, I'm taken to "Base Station" with 4 choices to click on (Armed, Disarmed, Schedule, Geofencing). Where can I adjust the sensitivity?
Hi Sydneyri,
It helps a huge amount to actually review the myriad of FAQs here that touch on most subjects asked here.
Skins won't help much but repositioning the camera and motion sensitivity settings can.
It's not usually the sun directly hitting the sensor but reflections from leaves, cars, etc. that are moving around. The skin's hood won't be of much help since most of that movement/reflection is well below what the skin can block.
