Multiple Wind audio notifications
One of my outside cameras seems to be triggered by slight wind movement. i get almost continuous audio notifications when the wind is blowing. It doesn't take much wind for this to happen.
Is there a way to reduce or eliminate these less than useful notifications? i tried a piece of tape over what i believe to be the microphone, but it didn't work.
Just disable audio detection in the rule.
Remove the camera and resync it. Any better? What mode are you using - Armed or a custom mode?
