Move Arlo Pro2 Base Station and Cameras
  • 2 Replies
  • 2481 Views
Holladay
I have an Arlo Go2 system. Base station + 4 cameras. I need to move the system to a new house that has different internet service. Can I simply remove the base/cameras and reinstall at the new location? Will the app (on my phone) still recognize the base station and cameras? Or will I have to go through the set up process at the new location?
Thanks in advance for the help.
You mention a GO camera, but I think you mean Pro as the Go doesn't use a base...
Answer is YES,.. you should be able to just move the base to the new location and plug in. If it sees the internet, it should start up without issue.  You may have to resync the cameras if they are offline for an amount of time as they loose sync after a while.
Holladay
Sorry, yes, Arlo Pro2, not Go (I have an Arlo Go too).
Thanks for the reply and that's good news!
  • 2 Replies
  • 2482 Views
