Motion Detection Is Not Working After Re Charge
Just re-charged one of our camera's and now it no longer picks up motion - do I have to re-sync with the base ? if I click on live, it shows the area its coveed, just that the "motion" is "greyed" out on the app.
No, the cameras should auto resync... If you can play LIVE , then it is connected.
The fact that the "running man" is GRAY means the camera is NOT armed for motion. Whn motion detect is on, the man is BLACK.
Check your modes for proper arming
i also have same problem my arlo pro2 quit picking up motion so i charged battery and it still dont pick motion up i can go to motion test and nothing
When you insert the battery do you get th blue LED to flash?
Hi Liz-W,
You can also try and do a quick reboot on the base station to see if this resolves the issue.
Hi loffutt,
I am glad that worked for you!
