Besides the motion sensitivity setting, you either have to position the camera in a way that triggers it quicker or you need another trigger.
PIR motion detectors don't easily detect an object coming directly towards the camera. They work most effectively with side-to-side motion. If you can position the camera to a slight angle, you'll get better detection and will hopefully still be able to see the person's face in the video.
The other option is another trigger eg another camera or an Arlo Security Light. You would then have a rule that this other device triggers your existing camera to record and you would position the second device closer to where the person was approaching from.
Other factors that may or may not increase the lag are camera-base signal strength and internet connection ping and speeds
Vehicles have a large IR signature that will trigger the PIR sensor from much further away. People have a relatively small IR signature.
You could try recording for a set length of time (up to 2 minutes) per motion activation but you will probably find you will need to charge/change the battery more frequently.
The Arlo Pro 2 with AC power will pre-record 3 seconds of video before the motion detection. Additionally, under power, the Pro 2 can have CVR (continuous video recording) so you never miss anything.
As to the recording stopping while the trigger car drives by, how slow is that car going?
Yes, hopefully at 100, you'll find it a lot better. In fact, you might find it too sensitive. I normally suggest people create a mode of their own and rules in the mode where the sensitivity starts at 100 and each time you get a false alert within 30 mins of a previous alert, turn it down 1. This allows you to fine tune the system to be as close to optimal as you can get. Most of my cameras work in the low 90s for sensitivity during the day and I schedule a night mode that has 100 for all cameras sensitivity.
HOWEVER, raising your sensitivity setting will make it more prone to vehicles triggering it. Again, the way to combat this is to reposition your camera or the other option is to subscribe to Arlo Smart but I'm not sure how effective that is
Share the video of the fireworks here. One, it'll be nice to watch. Two, it'll give us the POV of the camera and we can see if there's anything we can suggest re placement of the camera. Three, the link you share is only available for 24 hours so no need to delete it or be overly worried about it being seen by a large number of people
From the library, click on the ellipsis (3 dots) under the video. From there the options menu will give you the option to Share. Click "Share" and then click "Copy Link"
Then paste the link to your post here
1. Birds from 10 feet away setting off the motion seemingly right away.
https://arlo.netgear.com/hmsweb/users/library/share/link/BB4918B082D82D26_201807
2. A car that makes it almost halfway across the screen before recording begins.
https://arlo.netgear.com/hmsweb/users/library/share/link/5B9587F0790AA7C6_201807
3. The same car after it turned around to come back (i live in a cul-de-sac) in which the recording begins as soon as it emerges from behind the brick wall. Obviously triggering the recording to start much sooner than in the previous one involving the car.
https://arlo.netgear.com/hmsweb/users/library/share/link/B6E8363FC11F4B8B_201807
4. Three videos that involve my sister letting out dogs and pulling a few weeds. The recordings stop even though there is still motion. Recording seems to resume via further videos?
https://arlo.netgear.com/hmsweb/users/library/share/link/A57E85F2F4C9695E_201807
https://arlo.netgear.com/hmsweb/users/library/share/link/C515A9F791BE8209_201807
https://arlo.netgear.com/hmsweb/users/library/share/link/E0CC27C8BB8A46A9_201807
Notice in the last one she goes inside and about 10 seconds later the recording stops presumably due to no motion. Yet in the first 2, sister and dogs are still in motion when recording stops. Why don't they continue recording since there is still motion? Why not one long continuous video instead of three short ones. During the breaks in between, crucial images may not be picked up if those were intruders. Same issue with the street view videos.
https://arlo.netgear.com/hmsweb/users/library/share/link/548B51FCA6E5B040_201807
I have other videos of cars entering from the right side from behind the brick wall where the recording starts right away. There seems to be no consistency as to when the recording starts even when circumstances are the same across several videos that have different starting points. I also have videos of the same car emerging from behind the brick. In one of them, recording starts immediately after passing the brick. In the other, it has almost left the screen entirely before the recording starts. No consistency at all! A car in the background triggers it, but a person close up does not. The size of an object shouldn't make a difference. A big object in the bg and a small object up close take up the same amount of space on a 2 dimensional camera.
1) The birds are close and fast.
2) The car is partially blocked by your car. The big issue is that you're trying to use a PIR detection system to capture the whole scene. Do you want a motion-detection light to light up every time a car drives by? Rotate the camera down so it only sees your driveway.
3) The car isn't blocked by yours.
4) Define "motion". First, your sister stops moving for many seconds - the cameras detect that as lack of motion. If you want recording to continue in situations like that, use a timed recording for a long enough time. Then your sister is well out of range of the PIR detectors so recording stops. People detection is a max of 25 feet but can be less. And the last one just doesn't have motion except for a jogger (?) WAY in the background.
5) Maybe your car isn't blocking as much or the car in the street is further away from your curb. In any event, you're trying to pick up the wrong things for a PIR system.
I would definitely suggest you angle the camera downwards more. Also, change the video setting to Best Video for a sharper image
Two cars in the driveway and motion still detected from a car while still on the street behind them from closer to the left side of the frame. More obstruction and still recorded sooner. https://arlo.netgear.com/hmsweb/users/library/share/link/138FF319E1E330CE_201807
Earlier in the day. One car in the driveway, not two. Fewer obstructions. Recording doesn't start until midway through frame.
https://arlo.netgear.com/hmsweb/users/library/share/link/CAA63D609B87A535_201807
And here's one of another car pulling into my driveway behind the two cars already there. Note that it wasn't recorded coming down the street like the cars in the first video.
Please tell me how a car in the street with only one car in the driveway can delay a recording because the driveway car is "in the way" but when there are two cars in the driveway, "in the way", the camera saw past them and detected the street car sooner. Not trying to be a smartass, just trying to prove that with only one car in the driveway a recording of a car started later than a recording of a car when 2 cars in the driveway obstructed a street car. This is what I mean by no consistency of when recordings begin. The settings were exactly the same on both videos.
Your links have timed out (24 hour limit) so we can't see.
The issue of whether cars are blocking something in the street is really rather moot since that's not how these cameras work best. It's a distraction - focus on getting people detected best within ~25 feet or less.
1. I say that cars driving in the street aren't getting detected and I'm being told it's because cars in my driveway are blocking the street movement, yet I have other videos of street cars moving behind the driveway cars and they ARE being detected.
2. I have videos of visiting cars in my driveway already parked, but no videos were made of said car pulling in or leaving.
My point is that I'm being told that certain things are causing the motion detection to delay, yet those same certain things don't seem to be an issue in other videos. There is no consistency about how these things detect motion. One minute, a car doesn't get picked up until halfway through the frame and it's blamed on "parked car is in the way". Then, when the same parked car is still "in the way", another car comes by and gets picked up the entire time it takes to go from left to right while going at the same speed. Then of course there are the instances where there are no cars in the way, and I have video of passing cars being detected early and video of passing cars being detected too late.
Then there's the issue of why a car coming or going from my driveway wouldn't trigger a recording to be made. Or why a mailman stopping in the street, getting out and walking to the door and walking back doesn't get recorded (blamed on people being too small to give off a certain signature), but neighbors walking by on foot DO get recorded.
Let us know how you get on. It's always hard to get the perfect positioning and then the perfect motion sensitivity. There are always tradeoffs. That's why I always tell people to try out a location, if they can, before they drill holes for the mounts.
