When i sign in my unit will not show a mode setting, only device and library. It used to show all 3 but now only the 2.
Hi @xxxreoxxx,
Have you tried reinstalling the app on your device to see if that helps?
Hi @fall3non3,
Make sure your Base Station has the latest firmware version. Try to log out of the app, uninstall the app, restart your Google Pixel 2 device, reinstall the app and log back in.
Hi @xxxreoxxx,
Hi @fall3non3,
Thanks Jessica,
I had tested that already.
I got it working today by uninstalling the app, removing the base station from devices, redoing the install, resyncing the camera and reinstaling the app.
