4 camera set up. Trying to add a mode where 3 cameras detect motion & audo & push alerts while 4th camera has motion/audio detection turned off. Do I do this with just not including the 4th camera in the rules? One you add rule for camera it doesn't seem to let you unclick motion detection (if you don't have a trigger it won't let you save rule).
hints;
Only ONE mode can run at a time
Any camera NOT in the active Mode is off
Add a mode fro the three cameras... First add the first camera, then settings , then save
Go back and edit the same new mode to add the second and then third camera.
If you want all cameras active but no alerts from the forth, then just edit your current mode to turn off alerts for that camera
Correct. The 4th camera doesn't get a rule in the mode you make and it'll sit there and only be available to live viewing. Motion or audio will not activate this camera
