Bought Arlo Pro 2 ( Arlo pro 2 - VMS4330P - ID date 2019-06-13 ) with 3 cameras. Picture on box is what I got. 3 cameras and base station - rectangular with half circle rounded corners. Base station has one LED only. No text on base station. On back is ethernet - power - usb and reset. Nothing else. Arlo website set up does not recoqnise base station. Tried factory reset many times. My basic problem is, apart from the base station not being recoqnized, is that the LED colors explained in the manual are not what the single LED shows. Where is the manual that can be used with this base station ?
I do not use ARLO app on cell phone. Just arlo website on iMac.
You prob have the VMB4500 ( look on bottom of base unit )
here;
https://usermanual.wiki/Arlo-Technologies/18300391
https://fccid.io/2APLE18300391/User-Manual/User-Manual-4044857
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
