Minimum broadband speed required
My download speed is around 15 mbps however my upload speed is only around 1 mbps. Will the Arlo Pro 2 Work satisfactory with such low upload speeds. Obviously I don’t want to spend in excess of £500 on a system that will lag and be unreliable, thank you
The listed requirements in the spec sheet for the Arlo Pro 2 simply say "High-speed Internet connection".
The manual is a bit better, it says:
"Internet connection type (DSL, cable, and so on) and speed (Arlo requires at least 1 Mbps upstream)."
Looks like you are on the edge.
Just another user
