Notification per camera - Arlo Pro 2
I have 2 arlo pro 2 cameras and works great. Is there a feature to disable notificagion by each camera? So I want to have notification on for first camera and off on the 2nd camera. Should be a feature if doesn't exist.
Thanks!
Thanks!
In whatever Mode you're using, edit the Rule for the second camera and uncheck/untick the box that says Notifications. There's a box for email notifications and one for push notifications to your app
