I’m looking at both and don’t need Recording so is it really worth the extra money for the Arlo pro two?
Not really. The main differences are 1080p (Pro 2) vs. 720p (Pr0) and 3 second lookback for recordings which you've said you won't be using.
5 REPLIES 5
I’m looking at both and don’t need Recording so is it really worth the extra money for the Arlo pro 2 over the Arlo Pro?
For your stated purpose, no.
Sorry I meant to tell you there is only $35. Difference in the Pro and Pro2. So would that make a difference in which one to get?
Even with just $35. Difference?
