  • 3219 Views
LT29
Can you record continuous on the local drive or does it only record what is being recorded to the cloud?
the usb backup ONLY records the same as what goes to the cloud.... and this is only motion detected recordings ( not cvr )
no continuous recording
LT29
So What is on the cloud will be deleted after 7 days (for the free subscription). What is going to happen those on the USB after those 7 days ?
What do you mean it is only for motion detected ? Can i have it for cvr ?
ShayneS
LT29,
The subscriptions have different times before videos are removed. The Basic plan has 7 days, Premier plan has 30 days &  Elite plan has 60 days. After the 7 days on the basic plan, Your oldest dated recording will be removed for the newest recorded event. If you recorded to your USB Drive, those events will remain.
  • 3220 Views
