Would like to add another camera to the back of our house but our base is at the front of the house and the wifi does not reach the camera at the back. the back camera would be aprox 55 to 60 feet away from the base. I read about adding another base but it would still have to be hooked to our router in the front room of the house by Ethernet cable? would I have to have a cable running through all the rooms to reach the room at the back? Any suggestions?
You can use a wifi extender or powerline extender that has an Ethernet port and plug the base into that with the Ethernet cable. No need to run a cable from the router that way.
