  • 1 Reply
  • 2540 Views
Chuck_N
We had a "wind event" last night that generated motion triggers on a camera due to flag motion. This resulted in over 100 recordings. The flags will now come inside at night.
My question is: is there a "select all" function in the Library so the user doesn't have to select each recording individually to delete it? If Select All is available, how do I find it?
If this feature is not available now, are there plans to add it? It would certainly be nice to have.
2 things:
1) I strongly recommend never deleting videos since once they're gone, they're gone and can't be recovered. There's no space limitation even though it's stated so you're not at risk of losing anything.
2) Select all varies according to whether it's the app or browser. The Android app uses a long press on a video to activate multiple selections while the browser has a "Select" link at the top right of the library window.
  • 1 Reply
  • 2541 Views
