Cameras no longer recording movement? Library is empty, no longer have a rolling 7 day history?
Same here. No motion detected and no recording in library since 3/21. Help please!
Are the motion indicators for each camera i the Devices tab black or gray? Gray is disarmed. Check your active modes using a web browser - the apps have issues checking and displaying properly.
I have a similar problem. I still have old videos, but no new videos. Arlo had been working fine for a long while and suddenly it stopped, but the cameras and base station are working fine. There are a couple of similar recent posts so maybe it's a system issue that affects a lot of users?
Interesting. Are you saying that it switched to Disarmed on it's own?
Nothing changed on my unit that I can tell. It's armed and running, just not recording anything to the Library anymore. I was thinking that it would be something on the server side since nothing changed on my end.
After saying the above, I have my operational settings changed by themselves when I use basic activity zones.
