Keep losing connection Base Station VMB4000r3 and Arlo Pro 2. Tried removing battery.
  • 4 Replies
  • 1685 Views
aagaards
Lost the connection between base and camera.
I factory reset the base station and reconnect the camera to the basestation succesfully.
After 10 minutes the connection is lost between the base station and camera.
I tried to remove the battery from Pro 2 and reinsert again after 30-45 seconds and then the connection is up running again.
After 5-10 minutes, the connection is lost again.
All happens even though the camera is between 1-3 meters from the basestation.
WHAT TO DO??
aagaards
Tried to move the basestation about 1,2 meter away from the router - and that fixed the issue! 👌🏻
Is it only ONE camera?
Is the base very close to your router ( possible interference )?
aagaards
No, actually it is top cameras which have the same problems.
Yes, in March I updated my router to a mesh router and tv’et are placed 40 cm from each otter (same as before upgrading).
This could be it.
I have “tech”-Closet with all my devices (arlo, router, etc) - how much distance should Therese be betweeen basestation and router?
aagaards
good to hear
  • 4 Replies
  • 1686 Views
