I have the Arlo Pro 2 Base Station connected to 6 Arlo Pro 2 cameras. I’m not sure but after one of the updates, the base station hasn’t been responsive to the app (which has been going on for almost 2 weeks). No footage are recording and I have not been able to see live footage. Whenever I turn off and turn on the base station, it works for about 15 minutes or so, but then it stops.
When I’m on the app, it can’t collect information from the base station. When I go to the devices section, it’s constanly saying “getting information”...
I’m not sure what’s going on and I really don’t want to reset the whole system to factory settings because positioning all 6 cameras is such a chore. Anyone having the same issues or have a fix?
If your ISP is AT&T, there is a known issue they are trying to fix. I'm not sure what this could possibly be, and I got a poor explanation and apology on the phone for the "inconvenience". Frustrating.
I'm having the same problem. I was with Arlo tech support last night until midnight (before spoke with AT&T) just for them to tell me that they will keep investigatin the problem and will contact us within 24-48hrs 😞
Does anobody has any idea what is going on? This should be some kind of settings that AT&T has implemented that is blocking arlo's? Evertyhing was fine before 03/19...
@PM5 You and me both have $800.00+ dollars invested in Arlo. Like I mentioned in my previous post, yesterday. I don't think AT&T is the issue. If AT&T is the issue, I would believe there would be other issues with the entire Internet, not just Arlo. If you think about it, the Arlo login web address is not working, but other web links, URLs of Arlo works or else we could get on this forum to comment on things. I seriously think that Arlo may have updated, changed, or attempted to fix something that threw off the entire camera system. That's just my couple of cents.
Spent 90m minutes on phone with three different call centers for ATT in India. Finally got one to listen, They said they then found there is a "Network issue" but had no ETA to fix. That was 6 hours ago. My base station still does not connect. Hopefully ARLO folks are contacting ATT to say thier hurting thier customers.
What about the AT&T question? If your ISP is blocking for any reason, it won't work
I took my phone and computer to work and tried from thier Cable, I could reach the website just fine. This IS an ATT issue.
I do beleive there is some valid insites to the fact that Arlo may have done a firmware update on the base stations and BRICKED them. I have two base stations and both are off line. When I use the phone to access the MyArlo site over the wireless network, I can log on, but everything is grayed out, meaning it is useless. From my home on te computer, I can not access MyArlo at all. But I have other sites that are doing the same thing. So with net neutrality AT&T may be flexing it's muscle.
But could you see your cameras and base stations?
There is an issue with AT&T causing connection issues. Many users have reported this. Work with AT&T support.
No, just able to get to the wen site. The cameras and base station still cant get out due to ATT network issue. 😞
I guess, "I stand to be corrected!". AT&T just informed me that they're having issues with Arlo and that "AT&T are doing everything they can to resolve the issue." They also informed me they are trying to move certain formats something to the effect of DMZ, TCP or DCP around in order for the Arlo Cameras will work. They also stated that that certain ports needed to be open at which I mentioned that Arlo suggested ports "80, 123, 443" are already open.
What I don't understand is why I can't login to the https://arlo.netgear.com/#/login URL. And why did all of this just spontaneously just come up. One of these two companies, AT&T or Arlo must have changed something for this effect to occur. Why don't either company just reverse the changes so WE, Arlo customers can get back to normal.
Have tried all help steps suggested and still no connection. Two amber lights and nothing happening.
@YazooGirl Yes, we are all going through this issue...Have you read the comments on this thread. It's a freakin headache and a half.
We are aware of reports that some customers are experiencing two issues:
• Inability to access My.Arlo.com
• Arlo Base Station is offline
Our team is investigating these reports. We apologize for the inconvenience and will provide an update as soon as possible.
Here is a traceroute from my home in Texas to arlo.netgear.com and my.arlo.com. The last hop is in the EU (80.231.20.82). If your neighbor has a different ISP you can take your base station and plug it into their ISP router and see if it goes green. My neighbor has Spectrum, so will see when he responds.
Tracing route to ArloProdLB-1815857678.eu-west-1.elb.amazonaws.com [52.17.126.28]
over a maximum of 30 hops:
1 4 ms 3 ms 2 ms homeportal [192.168.1.254]
2 22 ms 30 ms 45 ms 172-5-100-1.lightspeed.snantx.sbcglobal.net [172.5.100.1]
3 23 ms 20 ms 20 ms 99.71.0.66
4 29 ms 33 ms 35 ms cr82.ftwtx.ip.att.net [12.123.154.114]
5 34 ms 31 ms 30 ms cr2.cl2oh.ip.att.net [12.122.2.209]
6 34 ms 30 ms 30 ms 12.123.18.233
7 28 ms 28 ms 28 ms 192.205.36.206
8 139 ms 139 ms 139 ms if-ae-37-3.tcore1.aeq-ashburn.as6453.net [66.198.154.68]
9 150 ms 149 ms 147 ms if-ae-30-2.tcore2.nto-new-york.as6453.net [63.243.216.20]
10 145 ms 147 ms 164 ms if-ae-32-2.tcore2.ldn-london.as6453.net [63.243.216.23]
11 141 ms 141 ms 152 ms 80.231.20.82
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
Check the growing thread in the Pro 2 section here. AT&T has an issue that can't be solved by Arlo. Beat on AT&T.
I have run a trace on the connection to MyArlo.
Traceroute has started…
traceroute: Warning: arlo.netgear.com has multiple addresses; using 52.210.203.231
traceroute to arloprodlb-1815857678.eu-west-1.elb.amazonaws.com (52.210.203.231), 64 hops max, 72 byte packets
1 10.241.159.227 (10.241.159.227) 2.355 ms 2.163 ms 1.954 ms
2 172-13-72-1.lightspeed.irvnca.sbcglobal.net (172.13.72.1) 22.399 ms 27.265 ms 43.393 ms
3 64.148.105.144 (64.148.105.144) 20.043 ms 20.329 ms 20.095 ms
4 75.20.1.38 (75.20.1.38) 23.421 ms 23.108 ms 22.104 ms
5 12.83.38.217 (12.83.38.217) 27.714 ms 26.135 ms 23.927 ms
6 12.242.115.3 (12.242.115.3) 29.894 ms 30.874 ms 31.957 ms
7 las-bb1-link.telia.net (80.239.193.213) 28.642 ms 24.603 ms 25.279 ms
8 ash-bb4-link.telia.net (62.115.137.38) 159.536 ms 159.795 ms 159.588 ms
9 ldn-bb4-link.telia.net (62.115.122.60) 161.765 ms 154.289 ms 153.836 ms
10 ldn-b7-link.telia.net (62.115.138.155) 171.647 ms 353.878 ms 172.700 ms
11 a100-ic-314219-ldn-b7.c.telia.net (213.248.89.70) 173.699 ms 182.650 ms 178.964 ms
12 * * *
13 * * *
14 * * *
15 * * *
Starts to slow down at step 8.
The ATT tech I talked with, stated that it was leaving the ATT network before it ran into trouble. But who knows, finger pointing.
Here is a different question but it pertains to this outage. I have an external 1TB hard drive connected to the base station. I thought in cases where the base station lost it's internet connection the cameras would still be captured on the external HD? That is not happening with this outage...I get nothing on the external HD (so what good is having the external?).
