  • 13 Replies
  • 5431 Views
  • 6 In Conversation
LJ07
 Hi there
I got a subscription for a month. First time having a subscription (had cameras for over 4 years) I cancelled due to not needing it anymore. Now I am getting "Issue loading feed event" I have reset the system, reset the cameras and uninstalled and reinstalled.
Please help?
13 REPLIES 13
ShayneS
Hi @LJ07 Are you still experiencing this issue?
LJ07
I signed back up to the subscription and it is working again. Absolutely bs. I had the feed for over 4 years before getting the subscription. So no it isn't fixed.
ShayneS
@LJ07 I have escalated this for you and support will be reaching out to you as soon as possible.
LJ07
They were meant to call me back but did not.
ShayneS
@LJ07
I notified the appropriate team and support is reaching out.
Glivig
After four years I am also not able to view recorded events.  They must have messed something up when they updated.  Time to purchase another company’s security camera
If this is with Pro 2 cameras, then you might need a back-end resync.  I'm tagging the mods - @JamesC , @BrookeN , @ShayneS - so they can check.
If you have different camera models, please let us know what you have.
Glivig
They are the pro 2 cameras.
This happened as soon as I didn’t renew my subscription.
Pro 2 and older cameras don't require a subscription at all unless you want features that otherwise aren't supported by the free 7 day plan.  As @StephenB suggested, the backend sync may be the solution. You can also try removing one of those cameras from your account and sync it again to see if that helps.
ShayneS
@Glivig
Can you reboot your base station and test again?
Glivig
I re synced one of the cameras and  they are now all working again.
Sage888
Mine is coming up with the same issue now
ShayneS
@Sage888
Are you still experiencing this symptom?
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
  • 13 Replies
  • 5432 Views
  • 6 In Conversation
