I am looking for a security camera system for my home/ property and came across the Arlo line. I was wondering if these cameras have to connect to the base station to function or just to my WiFi network? I have a shop that is 400 feet from the house and I would also like a camera that will monitor my driveway entry that is closer to 500' from the house. I am building out a wireless network that will cover a large area of my property so getting WiFi to those areas isn't a problem.
The Pro2 cameras ONLY connect to a base unit ( they set up their own wifi network ) and not a regular wifi router network.
If you are going to have a wifi network and the cameras are inside, then the Q camera will work for you really well.
Or you can use a wifi extender with an ethernet port ( hook the extender into your own wifi ) and plug the base unit into that
The Basic level of service ( free) allows up to 5 cameras total....
but, there is no limit on number of bases.
( multi bases is the only true way to expand coverage area )
So , yes you could run 2 bases and link the closest cameras to each. Max range is listed as 300 ft like normal wifi, but in real world more like 150 ft. for straight clear shot. Less if the signal travels thru walls, etc
