I have recently purchased the Arlo pro 2 camera system with 3 cameras. Is there any way to turn off notifications on 2 of the cameras and keep them on only one of them?
You can go to mode and then select that camera and in rules and uncheck notifications. Its at the bottom of rules.
Not the motion button. Are you at " Push Notifications" In the rule for that camera. Under that there is an option for e-mail notifications also. For motions you slide it to the left. That would work also but no recordings.
Are you selecting armed mode and then you get the option for each individual camera. Its the arrow at the right of armed motion detection on.
Yea your in the right place. That part is weird same here but you can select do nothing under record video or uncheck the push notifications at the bottom.
Yea thats the same here but your setting should work to not get any notifications or record motion. You said in first post you did not want notifications but if you want to record motion you can check the record video back on.
Then You would have to tap the record motion and check notifications if you want them on front door and do what you showed on others.
