Is there a way to turn off camera access to friends for short periods of time without taking away their access completely?
Yes... go to the settings and the primary account holder can disable any camera in your list...( device on - off )
only the primary account holder can turn back on
If you still need to use the cameras yourself, go into their account settings in Grant Access and deselect any cameras you choose.
If I turn off access to all cameras and leave access checked for only HOME does that deny access to all voice and visual?
I'm guessing HOME is the name of one of your cameras - is that correct? Or are you talking about geofencing?
I have three cameras and a base station and the icon appearance on the screen is that it is the base station. The cameras appear with a different con and then I have the option of a base station icon that is named HOME. I am not familiar with using geofencing so it is not that.
Do you have the latest app installed? The base doesn't show in Grant Access or am I misunderstanding? The siren shows up but not the base.
