Is ARLO PRO 2 Base Station compatible with SYNOLOGY Router RT2600AC ?
Is the ARLO PRO 2 Base Station compatible with SYNOLOGY Router RT2600AC ?
Thanks,
Steph.
Only if the NAS can be used as a USB drive. Most can't.
Thanks,
Steph.
There should be no reason why not as long as there is a spare ethernet port into which you can plug the base. If the internet light on the base turns green then you should be good.
OOoohh - ROUTER. I saw Synology and immediately thought NAS. Sorry.
